9 members (Hotrod Lincoln, sron48, FAST55, Uncles51, gswbbc, Hanks custodian, 32Fordpuchoptop, Joe W, 1 invisible),
158
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,479 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 118 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 118 | Lookin good!
Slow down your makin the rest of us look bad.
Have a happy thanksgiving. Ken | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | LOL. thanks ken... yea, i have done a lot since march when i got it, thats for sure.
leonard | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Did you start with oak boards. | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | bill, not sure what wood it was. it was there when i bought the truck. here is what it looked like when i first bought the truck. http://s251.photobucket.com/albums/...00/?action=view¤t=DSC01284.jpgbut since my truck is outside with only a cover on it, the south florida humidity and rain made it start to mildew, thats why i went with a dark stain. leonard | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | Leonard strikes again!! I'll give you this.....Leonard you are a busy guy! As Ken said, slow down!  You're puttin' us all to shame! Just kiddin'  Once again,good job! Jock  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks jock...
yea, once i get a project going, like my 57, i tend to go full bore ahead. fortunatly i had the funds to keep it going this long, and luckily it is "just about" where i want it, since the funds are starting to run dry. LOL.
now its time to just cruise it. put about 50 miles on it today, which was nice. the imediate things i want to do is get a spare tire winch form a new truck at my local j-yard so i can finally put my spare tire up under the back, then make a sheet metal bed cover. thats will be it for the short term. but as you all know, these things are never really done. LOL.
thanks again, and talk to you all later.
leonard | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Leonard, Looks Super, NICE JOB! An for future inquiries, your bed boards are "Red Oak". Tim
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks tim. i dont know squat about wood. LOL. red oak. cool.
leonard | | | | | Joined: Feb 2005 Posts: 338 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 338 | Red Oak. Cool! I like the way the grain came out.
Great job! | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | FANTASTIC bed job!
Will you please post how you under bed winch comed out with pictures Please? with yr, make, model of donor I was thinking the same thing for my 56.
Thanks Brad | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Great job Leonard! To help with the spare tire winch, here's some pix of mine. http://i281.photobucket.com/albums/kk203/Longbox55/100_0937.jpghttp://i281.photobucket.com/albums/kk203/Longbox55/100_0938.jpghttp://i281.photobucket.com/albums/kk203/Longbox55/100_0939.jpghttp://i281.photobucket.com/albums/kk203/Longbox55/100_0940.jpgThe winch itself is from an '88/'89 C 1500 (any '88-'98 will do, 4x4 would be preferred, though) the cross member it's mounted to is a 2x3 with an additional mounting added to it and a brace bar to prevent rotation of the crossmember with the tire on it. It's mounted to the frame using existing holes. I only had to drill 1 oval hole to allow the winch shaft to pass through at an angle to clear the lisence plate. The other cross member shown came off the donor truck, and is a support for the shaft. I did have to alter the end that holds the tire by adding 2 extension plates. That was due to using a 2wd winch, which is for a wheel with a smaller index bore. The 4x4 or 3/4-1 ton versions have a larger tire retaining peice, and would be preferrable. For the crank mechanism (those peices were missing from the donor truck in my case) I used a McGuard Spare Tire Lock kit, which incluseds a keyed shaft that goes on the winch, and a long 5/8" hex keyed shaft to operate it. As I don't have the ratchet that the donor truck usied, I'm using a 1/2" ratched with a 5/8" deep socket to operate it. I suggest the deep socket for maximum contact to the key shaft to prevent slippage/twisting.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | thanks brad. i have not found a spare tire winch yet. still looking. need to hit a few more local junk yards. soon. when i do i will surely post some pics.
longbox55, very cool install you did. i love it. now i am really pumped on getting one. can you please post a pic of where you run the tube out by the rear bumper ? i would like to hide mine up under the truck if possible.
thanks again guys.
leonard | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | | | |
