3 members (Jon G, Otto Skorzeny, 1955 1 Series), 85 guests, and 2 robots.
Topics128,026
Posts1,055,399
Members48,422
#476850 11/30/2008 5:03 PM
TRK
Offline
Apprentice
Apprentice
Just purchased a 235 for my project. Wanting to upgrade to hydraulic lifters and found an engine with 65K miles. From a 1955 Belair.
Is this a full pressure oiler? It has the Oil cannister on the side. And had the Automatic Transmission. I have the numbers listed below. I tried to look the numbers up but were getting some conflicting reports.
Block 3836233
serial 035447 7T55Y
Head 3835913
Going in a 1953 3600 P/U
Tim
http://www.facebook.com/album.php?aid=1561&l=f7822&id=1607350326
1953 Chevrolet 3600 3/4 ton
1951 Chevrolet 3100 parts truck
Sometimes you just need help!
TRK #476871 11/30/2008 6:10 PM
If it is from a 55 it has the full oil pressure system.
Fred
Riding in the Passing Lane
If it came from a power glide car it has hydraulic lifters.
1972 Chevy c10 Cheyenne Super
The engine and transmission code should be a Y for a 55' 6 cylinder with PG and 136HP. With only 65K on it I'd clean it out, clean it off and run it. Cool find.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Your engine no. confirms it: it's a '55 from a powerglide equipped car, full pressure oiler with hydraulic lifters.
I agree with waldo53. I have a 3836233 block as well. nice find.
TRK
Offline
Apprentice
Apprentice
Thanks for the info, I will clean up the engine and do a compression check. It came out of a very nice 1955 Belair that was being upgraded to a V8.
I will make a test stand and get the engine running just to make sure it is OK.
My original engine was good, but needed gaskets and cleaning. But I wanted to upgrade to the hydraulic lifters, and full pressure oiler.
Tim
