5 members (rfs56trk, Gib70, Lightholder's Dad, Gray_Ghost, 1 invisible), 134 guests, and 1 robot.
Topics128,080
Posts1,056,060
Members48,433
#477005 12/01/2008 1:16 AM
on my 59 viking 60 the brake pedal is attached to the lever connected to the master cylinder( there is a song here somewhere) by a threaded end on the brake pedal shaft. How do you get the pedal loose from the lever? Is it a press fit? Does the brake pedal have splines? I can't take it out as a unit because the pedal shaft goes through the cab floor. Tried a little puller but no luck. Heating is next unless someone has a better idea. Any suggestions?
Matt
"Brunhilde II" '59 Viking 60
To paraphrase Ben Franklin: "Big Bolts are proof that God loves us and wants us to be happy"
usually requires a BFH with the nut backed off to prevent buggering the threads ... I seem to recall the pedal part is lightly splined but the hole in the lever isn't, really just a press fit that gets rusted pretty solid after years .... keep fightin grin
tough place to swing a hammer.
Matt
