| | | Forums66 Topics128,109 Posts1,056,240 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | Is it possible to remove the steering column from the cab without removing the steering box from the frame? Also is there any company that makes a oem style replacement steering box set up for power steering?? | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Not that I'm aware.... I pulled the column/box assy before i took off the cab....  | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the column doesn't seperate from the box, all one piece that needs to be removed from below .... power steering requires a modern power steering box spliced to your cut off upper column, or a complete column assy from later year
Bill | | | | | Joined: May 2008 Posts: 88 Shop Shark | | Shop Shark Joined: May 2008 Posts: 88 | I had a feeling that the column would have to come out of the bottom of the cab. does anyone make a new power steering column that mounts thru the oem frame holes and uses the stock pitman arm?? I was thinking of using the column out of my 1982 c-10 but i have never done a transplant like that before also the steering box mounts the pitman arm down and not thru the frame like the stock 59 does. my replacement motor has a good ps pump and hoses i just need a box to fit them to. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The specialty parts suppliers have a kit to install the GM power steering gear to the older trucks. I havn't done one yet but am contimplating it on my 58. Some also use the Toyota 4X4 box although i'd hate to put anything from a foriegn vehicle on mine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | the toyota 4x4 box is by far the easiest swap. box must be pre-85' (solid axle)do your homework before you start. | | |
