10 members (Johnny Rib, 68ironhead, 2-Ton, 1955 1 Series, JW51, baldeagle, Guitplayer, walter74, Eisenholtz, Peggy M),
104
Mod | | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47696 07/14/2005 5:52 PM | Joined: May 2005 Posts: 86 'Bolter | | 'Bolter Joined: May 2005 Posts: 86 | Will the stock fan blade from a 235 water pump bolt up to a 216 water pump. I think I read somewhere that the bolt 0atterns are differnt?
Mike 1951 Chevy 1/2 ton w/ 1959 235 1971 Chevelle
#47697 07/14/2005 9:16 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The fan from my 216 would not work on my 55' 235 engine. Had to use a fan from a 56' Chevy car to clear the crank pulley w/ a 090 spacer. The bolt pattern was different too as I recall. | | |
