Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (Peggy M, crenwelge, Wayne67vert), 182 guests, and 5 robots.
Topics128,282
Posts1,058,494
Members48,490
#47683 07/14/2005 4:01 PM
Anyone out there ever paint their carburetor? I can't say that I recall seeing any that have been painted. I thought since I have mine off to rebuild it, that I might go ahead and paint it. The body seems to be an aluminum casting with an iron casted base adapter.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
#47684 07/14/2005 4:17 PM
I wouldn't because any leak will make a mess out of the paint job. While you have it a part take a Dremel and polish it some; will look better in the long run. Plus paint could gum things up, ie. linkage ect. Ben
popcorn The Truth is Out There (I would worry about the Carb holding more heat also. Just my take)
#47685 07/14/2005 4:25 PM
Eastwoods has a paint/coating for carborators. It comes in silver and gold color. I used the silver on my carbs, it works fine.
George
#47686 07/14/2005 5:20 PM
Quote
[Sarcasm On]
Yeah Ben, I had the same problem when I painted my doors. Since I didn't mask it, the paint got all over the edge of the glass and made it kinda hard to see out the windows. Not to mention it got all over my door handles. Next time I think I'll just let the doors rust till they fall off. grin
[Sarcasm Off]
Seriously, Bob,
Like any painting project, I would take measures to not let paint get where it shouldn't, such as on the working parts of the linkage. smile I had not thought about retaining heat though. I'll take that into consideration. Thanks for the heads-up. smile
Rance
PS: I sure hope you have a sense of humor. smile
#47687 07/14/2005 5:49 PM
PAINT isn't appropriate for a carb, and will gum things up when the gas starts dissolving it Rance, and the heat retention is important - carbs and manifolds work better if cooler - there are special coatings made for carb bodies, if you think you need the show truck look, or you could have it powder coated - the OEM look is a special thing like anodizing, and can usually be regained by cleaning it well, or using the stuff from Eastwood or similar, which is fairly impervious to gas and leaves the carb looking aluminum or the bronzy finish that some have
#47688 07/14/2005 6:32 PM
Rance: I guarentee I have a sense of humor; You do not know POP'S to well yet I have to laugh at life!
The heat retention is a big thing, I come from a long back life of drag racing and now my boys dirt track racing. Back in the 60's early 70's we did everything especially the old aluminium foil wrap around gass lines. Ice on intake manifolds anything to get gas colder. Ben
popcorn The Truth is Out There (Tease on I love a good razing)
#47689 07/14/2005 10:20 PM
sense of humor,,,is that a requirement for posting here,,,,,,,,,,, grin grin Fred
Redryder pix
My Hotrod
#47690 07/14/2005 11:21 PM
My Carter W-1 was painted black originally and the paint has never been disolved in over seventy years.
Baldy
#47691 07/15/2005 3:59 AM
I painted one of the numerous carbs that I had on my 302. Used regular engine paint and it held up fine. It is all in the preparation.
Jason
#47692 07/15/2005 9:49 AM
I used the normal por15 (not the engine paint)for the engine and the carbs. It resists oil and gas and can stand the heat verry well.
I alo used it for the carbs. No problem sice years (and I can tell you the paint saw some solid amount of oil and gas :rolleyes: ).
But you have to paint them when disasembled, without gaskets and all. grin
Frank
#47693 07/16/2005 4:41 AM
Junior Member
Junior Member
Rance, Popcorn, Red58, I sure hope you guys don't spread the word that carbs and intakes run better when cooler, what would Tom Langdon, and most of the bolters on this board think. Can you say "mutiny".......haha and I agree with you whole heartedly. Cooler is better.
#47694 07/16/2005 5:54 PM
Best paint I've used for carb base was appliance epoxy, stands up to the gas, getting hard to find now days in black. Also I've used the silver carb paint from Eastwood, very good stuff. Another pricy option would be to powdercoat, would last for ever.
1946 1/2-Ton Chevy
#47695 07/17/2005 2:35 AM
JiMerit....bought 2 cans of black yesterday at Ace Hardware...You might give them a try
"All right, they're on our left, they're on our right, they're in front of
us, they're behind us...they can't get away this time"
Lt Gen. Lewis B."Chesty" Puller, USMC
