| | | Forums66 Topics128,026 Posts1,055,406 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2008 Posts: 26 Apprentice | | Apprentice Joined: Aug 2008 Posts: 26 | Just purchased a 235 for my project. Wanting to upgrade to hydraulic lifters and found an engine with 65K miles. From a 1955 Belair.
Is this a full pressure oiler? It has the Oil cannister on the side. And had the Automatic Transmission. I have the numbers listed below. I tried to look the numbers up but were getting some conflicting reports.
Block 3836233 serial 035447 7T55Y Head 3835913
Going in a 1953 3600 P/U
Thanks, Tim
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | If it is from a 55 it has the full oil pressure system. Fred
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If it came from a power glide car it has hydraulic lifters. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | The engine and transmission code should be a Y for a 55' 6 cylinder with PG and 136HP. With only 65K on it I'd clean it out, clean it off and run it. Cool find. | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Your engine no. confirms it: it's a '55 from a powerglide equipped car, full pressure oiler with hydraulic lifters. | | | | | Joined: Sep 2008 Posts: 84 New Guy | | New Guy Joined: Sep 2008 Posts: 84 | I agree with waldo53. I have a 3836233 block as well. nice find. | | | | | Joined: Aug 2008 Posts: 26 Apprentice | | Apprentice Joined: Aug 2008 Posts: 26 | Thanks for the info, I will clean up the engine and do a compression check. It came out of a very nice 1955 Belair that was being upgraded to a V8.
I will make a test stand and get the engine running just to make sure it is OK.
My original engine was good, but needed gaskets and cleaning. But I wanted to upgrade to the hydraulic lifters, and full pressure oiler.
Thanks, Tim | | |
