6 members (55shaker, MickeyP, Shaffer's1950, Ranger, KCMongo, Otto Skorzeny), 74 guests, and 0 robots.
Topics128,051
Posts1,055,705
#476542 11/29/2008 9:29 PM
TPB
Offline
I have a 1951 Chevy 3100. I sent my fuel gauge out to be repaired and when we installed it it says on full. please help
TPB #476545 11/29/2008 9:37 PM
jdl Offline
A ground is not connected somewhere. Check all of the connections and wires from the gauge back to the tank and sending unit ground. If all those check out, then check the sending unit in the tank. It could be bad. That was the reason that mine wouldn't work.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
TPB #476819 11/30/2008 3:18 PM
TPB
Offline
Is the sending unit difficult to install?
TPB #476841 11/30/2008 4:37 PM
jdl Offline
Nope, you just undo the screws that hold it in and pull it out of the tank. On mine the metal band that goes to the little box that holds the float arm had broke. I'm assuming that our two trucks are relatively the same on this part but I don't know. I'm only 13 and learned this by doing it. After I installed one that someone gave me it worked fine and seems to register correctly.
Jordan D. Long
Photobucket
jdl #476859 11/30/2008 5:24 PM
you can pre-test it outside the tank.
hook all 2 wires and work the arm up or down.
ground wire are always important ... anywhere
Jim & Caroline
