0 members (), 234 guests, and 9 robots.
Topics128,078
Posts1,056,052
Members48,433
#47666 07/14/2005 2:04 AM
No, it aint a personal question wink
Actually, I'm refering to the dipstick tube. I'm having a 1955 235 rebuilt to go into my 1940 GMC. I ordered a new tube from Jim Carter. They sent me a genuine GM tube, but its about 2-1/4" longer than the old one. So I'm wondering if it is suppose to be cut to length or if my original was shortened at some time.
Measured from where it comes out of the block to the top, my original is 6" long. The new one is 8-1/4" long.
How long is yours?
Steve
See my 1940 Canadian GMC:
http://community.webshots.com/user/ndnchf
my 57 looks like 7½" - I'd just cut it so the same amount of dipstick sticks into the pan as it did before, which is what counts - maybe there was variation in oil pan size, and the factory one was a 'universal' size meant to be cut for the application, or maybe they just make new ones that long so ya feel inferior grin
smile
ndnchf -
Here's what I did.
Fill your crankcase with the proper amount of oil needed for your engine (5 quarts) and than cut the tube so that the proper amount of the dip stick is in the oil to show the crankcase full on the dip stick.
Remember - size (or length) doesn't count; it's how you use - er - your dipstick!! grin
Joe
Steve,
Like Joe said... And don't forget to make sure you are parked on level ground.
If for some reason you wanted the top of the dipstick to be higher (easier to reach), NOW would be the time to make that viable. Instead of cutting the top of the tube off to fit your current dipstick, get a longer dipstick so you'll be able to 'adjust' the dipstick tube to the new dipstick. And don't forget that there's generic dipsticks you can buy that are adjustable. Pick and choose which method(s) work best for your needs. smile
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
Well, I think I'll put the old tube back in, fill it with oil and verify the level is correct on the stick. If it is correct, I'll cut the new one to match and swap it in.
Thanks guys,
Steve
Just went and measured. The tube is 6". Dipstick from cap to full mark is 13".
Whoever said size doesn't matter is lying. grin
Fred
52 3600
69 C-10
