3 members (1955 1 Series, DaveV, stlcardinalsguy), 120 guests, and 2 robots.
Topics128,150
Posts1,056,821
Members48,456
After completing a swap where we replaced a 216 with a 261, we find that the mechanical temp sender does not fit the new block properly. Although the threads fit fine, there is nothing for the sender bulb to bottom against in the block, so it leaks. I am guessing that there is some sort of fitting that goes into the block first, that makes the sender fit and not leak. Can someone give me a clue pr send me a pic? Thanks very much.
Jim
Some people have reported that NAPA has the temperature adapter as Balkamp part #701-1542. Also, Jim Carter and other vendors sell an adapter. You might want to use blue rtv sealer but mine does not leak without it. The correct adapter has a "rim/shoulder" that the temperature sender seals against.
