Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Peggy M, cmayna), 226 guests, and 4 robots.
Topics128,282
Posts1,058,495
Members48,490
#4766 11/20/2004 7:50 PM
Neither of the two distributors I have for my 270 have vacuum advance. I have never seen anything without but the book doesn't mention it on the larger trucks. Should I buy one of the advance units or go without? Also, what does it mean when an engine has no serial number? Mine is just stamped with "270"
#4767 11/20/2004 8:12 PM
so far as a serial number, I don't know if I would call it that. I don't think the engines were coded with a specific id#, but the casting number should be visible. You just might need to scrape through some gunk to expose it. On my Chevrolet inline, it is located on the passenger side of the block. You can also pull off the valve cover and see the head casting number stamped underneath the rocker assembly. The head doesn't always match the engine but the numbers could prove useful down the road. I am not sure if GMC stamped their casting numbers in a different area, someone else will chime in if this is the case.
So far as the vacuum advance is concerned, most if not all the inlines that I have seen, have always had a mechanism. They are not hard to come by, many of the fine links listed on this site sell them. Again, someone else more knowledgable will probably chime in on this. Good luck. wink
Whad you do?!?
Shane
1953 Chevrolet 3600
