4 members (JoergK., tclederman, Danielbolt, Peggy M), 177 guests, and 2 robots.
Topics128,175
Posts1,057,052
Members48,460
#47632 07/13/2005 5:17 AM
hey everyone
i'm on a few 4x4 bulletin boards too, and i just ran across a thread that mentioned eaton axles hybrided (is that a word?) with some 14 bolt axle parts.
the one that really intrigued me was someone that mentioned the commonly available 14 bolt disk brake conversion kits were a match for the eaton axles... details were scarce, and it seemed there was some chance of the gears working too.
anyone heard of this?
-bryan
i'm going to bump my own thread here... apparently the 14 bolt detroit locker will fit in the eaton housing if you use the 14 bolt axle shafts. unfortunately those of us with the narrow eaton axles are probably still screwed on that one... i'm looking for more
oh yeah, the dana 60 brake drums might be useable with slight modification
I asked this on the 67-72 board, got the same answer you did. A housing swap is about the only way. And it is possible with the right wheel setback. I'm just not fond of the looks of the 14 bolt under one of these trucks.
Fred
52 3600
69 C-10
#47635 08/31/2005 10:25 AM
Being kind of new to this stuff,is the Eaton axle you're referring to the one used in,say,a '62 one ton?
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
Fred T
i don't like the 14 bolt under there either. the eaton looks much better. i am intrigued by the disk brakes though, even an easy source for replacement drums
speed
yes, as far as i konw that is the same axle as the one under my 52 3/4 ton, at least the basic design is. i'm far from an encyclopedia on this, but i think yours is full width compared to mine.
