4 members (baldeagle, NorCal52Suburban, DaveV, Opelika Tom), 107 guests, and 1 robot.
Topics128,037
Posts1,055,470
Members48,424
#47626 07/12/2005 10:55 PM
I need to ID my carb. in my 66 Chevy 1/2 ton so I can get a Carb. Kit. About the only number I can find is on an aluminum tag under a screw.
It looks like either (A K5 1B) or (A K5 18)
The only other numbers I can find are obviously casting numbers inside circular bosses on each component. The only other markings are RP Rochester blah blah blah.
As I understand it, since it is a Rochester, I should see B, or 2G, or 4G. Can anyone help? Thanks.
Also, just above that tag is 7024008. This seems to be more helpful. Is this a rebuild tag? I don't care as long as it helps me ID my carb. grin
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
#47627 07/13/2005 1:08 AM
the tag is the best ID - identifies the exact configuration of the carb - take it to the parts house, tell'em what engine it's from, and they'll know exactly what the carb is - if it's a one barrel it's B, 2 barrel= 2G, 4 barrel= 4G, if it's auto choke there's a C as well, like 2GC - pretty simple - any other number is 'generic' and doesn't tell you the jets and application, so treasure that tag in case you need to buy a replacement some day!
#47628 07/13/2005 2:02 AM
V
V Offline
take that tag to a good parts store and they can match up a kit or replacement carb.if they cant then you need to find a real parts store
