| | | Forums66 Topics128,034 Posts1,055,542 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | Pulled the intake on this little 283 and found lots of sludge. Carefully cleaned her out, we will see. Would like to get at the pan but that is a pain in the a$$ [IMG] http://i16.photobucket.com/albums/b11/Toomanyhobbies/032.jpg[/IMG] | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I think you should take it apart, have the whole thing hot tanked, and rebuild it. Modern cams are so much better anyway, and don't cost that much if they're flat tappet. And there are some really good heads out there that don't cost much either. Check out Summit and GM Performance Parts for starters.
That sludge could be in some critical oil galleys too. If the sludge is that bad, I don't think I would want to trust it.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | Hot Rod Dad, I agree 100% with you. Right now I am on a budget, just finished a kitchen/house remodel.
If I do pull the motor, I would dump either a 350 or a 383 stroker in her. I am leaning towards the stroker. I built one for one of our Camaros, serious torque and of course traction problems. | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | | | | | | Joined: Nov 2008 Posts: 12 New Guy | | New Guy Joined: Nov 2008 Posts: 12 | Have you thought of just flushing it with half and half oil/kerosene mix? then drain and refil with oil. Most folks who do this are very happy with results after idling the engine for 2-3 minutes with this mixture. John | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I wouldn't want kerosene going through my engine bearings for 2 or 3 minutes with the engine running. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | Add a litre of Auto tranny fluid to the oil, run for 10 minutes at idle then change oil and filter....ATF is high detergent and will clean out the motor a bit.... | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | I second the auto trans fluid | | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | I have heard of these tricks, but advised against them. I am hesitant to loosen it up and clog an oil journal
| | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | ATF Fluid,It will do less harm that aggresive mechanical removal....it will disolve the sludge gradually, not in chunks/bits and pieces... my 2 cents.... | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I myself would pull the pan, remove as much as possible and use 1 qt of ATF in lieu of 1 QT oil for the first few oil changes. I have done that for years. I have also used the 1 qt of diesel in the engine just prior to an oil change. With engine warm, add diesel, run engine for about 30 seconds, then shut off and let sit for a minute. Change oil often.
Then if the engine starts to rattle, re-build it.
| | | | | Joined: Nov 2008 Posts: 137 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 137 | Thanks Scott. My thoughts exactly going to pull the pan and clean it out. May try the ATF. If it goes post toastie then I will put a 383 stroker in. | | |
