0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#47607 07/12/2005 5:22 PM
I have a one -half ton Chevy truck with a 235 c.i. six engine.This is a 62 year truck The truck also has an add on air conditioner which requires a little help in the cooling compartment. I have the original four blade fan. Did Chevy make a blade with five or six blades? The truck does not overheat but a mechanic suggested an upgrade on the blade to help cool the AC condenser as well as the truck. Any suggestions from anyone with this problem? Thanks in advance for any ideas!
Green Machine
#47608 07/12/2005 7:15 PM
I have had over heating problems at idle since adding a/c. Running down the road is not a problem. I tried electric pusher fans hidden in front of the raditor with a mechanical fan in back. That won't work due to a vortex between to two fans. I tried just the pusher fans without the mechanical. That didn't work due to the electric fan diameter is limited to the width of the condener. I am now trying a friends puller electrical fan with shroud with no mechanical. If it works I'll buy one. Yes, it looks like you know what but I have to have more air flow at idle and my wife says I'm not turning the A/C off waiting to get into a show.
#47609 07/12/2005 7:16 PM
#47610 07/12/2005 7:32 PM
I have seen a 5 blade fan on later sixes, is your fan close enough to the radiator? Sometimes a spacer can help. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#47611 07/12/2005 10:42 PM
Riding in the Passing Lane
A good quality alum. flex blade fan works good.
1972 Chevy c10 Cheyenne Super
#47612 07/13/2005 5:09 PM
1 Offline
if y ou have a fan (or pair of them) that move enough cfm, and they are properyl installed in a shroud, you should not have any problems. many aftermarket electic fans especially the smaller ones (like 16" and under) don't move a whole lot of air.
you may not want and ford parts on your truck, but i have on on my '03 ford truck that i used to replace the mechanical fan. no problems with a/c sitting in traffic on a 105 degree day. i plan to use the same fan on my '59 chevy 36. it is a 2-speed fan that moves like 3,500 cfm on high.
2003 ford lightning
1959 chevy 36
#47613 07/13/2005 5:26 PM
There are several aftermarket "flex" fans available, some with as many as 6 or 7 blades. They pull a lot of air at idle due to the deep curve of the blade, and straighten out and pull less air, (and make less noise) at higher speeds due to the blade's curve straightening out. Most of them fit a variety of bolt patterns due to slotted mounting holes.
#47614 07/13/2005 5:55 PM
Junior Member
Junior Member
I HAVE AN ORIGINAL 6 BLADE FAN THAT CAME FROM A 1956 1/2 TON CHEVY TRUCK (235 MOTOR)
#47615 07/16/2005 10:41 PM
I really appreciate all the responses to my question! I ended up having my radiator serviced-had a few leaks - and installed a larger four bladed Chevy fan-one that was about an inch longer. I will test the new fan. If that doesn't work then my next step will be installing a flex fan or try to find a six blade Chevy fan. I am trying to stay as close to original equipment as possible and the flex fans are just too pretty and shiny!! Thanks again guys!
Green Machine
#47616 07/18/2005 7:09 PM
mid 60's on, the 292 chevy uses a 7 blade, 4 bolt fan
Jim & Caroline
#47617 07/18/2005 8:54 PM
Do you have a fan shroud? That will make a huge differance.
Paint & Body Shop moderator
