3 members (Lostbuthaulinass, MNSmith, festerhairball), 99 guests, and 2 robots.
Topics128,057
Posts1,055,814
#474565 11/23/2008 7:30 PM
Have any of you ever swapped a '60 - '66 short panel body onto a later GM pickup frame/running gear? Major surgery involved here, or is it as relatively easy as a straight body swap?
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
patrick66 #476003 11/27/2008 9:10 PM
you can unbolt a mid 80 truck front sup and cross member and bolt it in a 66 with very little mods even use the later steering box
