Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Hotrod Lincoln), 129 guests, and 4 robots.
Topics128,275
Posts1,058,571
Members48,492
Hi,
Any ideas where to source a drive shaft for a 1952 Cyevy 3800 series?
thanks
'50 Chevy 1 ton dually daily driver, 1960 Ford F-100, 1972 GMC C-20, 1958 Kenworth, Cat D4, 1972 Ford F100 Ranger
Fred
52 3600
69 C-10
Boom and his Dually
Welcome to the Bolt! Do you have the old one? Do you have a 4 wheel drive shop around you? If you do call them they will know of someone (hopefully local) that can fix yours or make you a new one. Good luck!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
yes, i do have the original. literally the original. i'm in Fallbrook CA (North County) SD. Should be able to find a shop nearby.
Good idea.
