0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#475807 11/27/2008 3:14 AM
Apprentice
Apprentice
I want to swap a tilt wheel setup into my 56 TF with a sbc and 700r.
What GM columns should I be looking for that will have the shift indicator pointer on the column and not in the dash? Or does someone sell some sort of indicator adapter.
'67-'72 Chevy truck, and I beleive the G series vans from '71 up to around '81 or so. something to note about the vans, they still used the dash mounted ignition switch, which makes them desireable for swapping. You might also look in the Step Vans up to the '80s, not sure how many actually got tilt columns, though (I have seen them with them).
Bill Burmeister
Apprentice
Apprentice
Longbox55,
Thanks for the info. Will look around the j-yard next week.
Has anyone figured out a way to use the in dash pointers from later columns?
Bob
