2 members (Gdads51, 1 invisible), 92 guests, and 0 robots.
Topics128,052
Posts1,055,743
#475788 11/27/2008 2:01 AM
I put the wick seal on my 62 235. Later on I am reading that the neoprene should go on the later models. Does it matter which? the wick seamed to fit. But if I'm going to get leaks, I might as well change it before I get it completely together.
[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
davidn #475790 11/27/2008 2:16 AM
The neoprene works well. I did have a problem with them in my 1955 235, but some silicone on the outside solved that.
You should have no problems with your late model, probably no silicone needed, just follow the instructions that come with the seal.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Grigg #476702 11/30/2008 4:49 AM
A new Neoprene in my 57 is leaking cry
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
Maybe someone can comment on this but I believe that they came from the factory with the rope. The neoprene seal is much nicer to deal with when the motor is in place. No seal will work well if the main bearings have too much clearance.
1951 1 Ton Completed
A neoprene seal will only work if the seal surface is without pits, has not been turned more than a few thousands and has a seal groove that is concentric with main bearing journal (I have seen them offset). They will also not work well with a engine that has shims on the rear main.
My Blog
now I don't feel too bad about putting the rope in without thinking about it first.
