7 members (LAJones48, Barry Martak, Otto Skorzeny, Waveski, Shaffer's1950, Rusty Heaps, 1 invisible),
110
Mod | | | Forums66 Topics128,094 Posts1,056,465 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | HI.....we have an after market turn signal mounted to the steering column the chrome kind that are sold on Ebay and places like Classic Parts. The arm hits the top of the case and produces a rattle at a certain RPM. I need to take the top of the case off and enlarge the slot with a motor tool. When I remove the two screws will anything spring out like a "jack-in-the-box"? T/C Steve | | | | | Joined: Oct 2008 Posts: 88 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2008 Posts: 88 | BOOM... Just take it slow. Have you considered a small piece of foam or something to keep it from rattling. Just a thought. | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | BOOM......I think I will disconnect the battery first....good point! Foam...can't fit a piece where it needs to go the gap is that small. But MAN does it make noise!!! T/C Steve | | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | Last week, I completely disassembled, cleaned, and repaired my original unit. Two wires had shorted out, the indicator light was burned out, and the unit had the beginnings of a bee hive inside. It's not very complicated. Nothing will spring apart when you take the cover off. However, if you disassemble the whole unit, there are two electrical contact plates inside which are separated by a spring. Mine did spring apart, but it was easy to figure out. My unit is back together, and all blinkers and flashers are working properly! | | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | If anyone is interested I contacted Truck-Lite Company. Their customer service rep sent me data and schematics for the Sigflare900. I will post a link if it does not violate any copyright laws. | | |
