| | | Forums66 Topics128,269 Posts1,058,402 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 136 | I have a vacuum gauge in the dash of the 58. The 235 idles at 20 but when you get it a shot of gas it drops to about 5 and comes right back up. Can you tell anything by that?
Lindsay | | | | | Joined: Sep 2008 Posts: 125 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2008 Posts: 125 | Vacuum is always higher with the throttle closed. When you open the throttle reducing the restriction it drops, until rpms pull more air through the carb, then the opened throttle becomes restrictive again (to the bigger chunk of air being pulled in) and vacuum rises again.
Who is John Galt?
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | You can use a vacuum gauge to set ignition timing, but it is best used along with a tachometer. I have found the best results by advancing the timing until either the RPM or vacuum reaches a peak, then retard the timing to give about 1"Hg drop in vacuum. I have found that method gives a close approximation to manufacturer's specifications. Using a vacuum gauge alone, going for peak vacuum will usually leave you with timing that is advanced more than is desirable for your engine and operating conditions- engine load, altitude, ambient air temperature, etc. Others have their preferred method of setting timing using a vacuum gauge, but they also advise to listen for detonation/spark knock/pinging, and to retard timing until that no longer occurs. The best approach is to use a timing light.
The information on vacuum gauge readings contained in the link in the previous post is weak or incorrect on several points. If you search the forum using "How much vacuum?", there are responses there to give you more insight on the topic. Make sure you use the quotation marks, otherwise the search produces more responses than you will care to read.
Harvester | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | Harvester,
I'm having trouble understanding why a vacuum gauge is best used along with a tachometer. Is the tach just used to set the initial RPM before using the vacuum gauge.
You say to advance the timing until EITHER the RPM or vacuum reaches a peak, then retard about 1"Hg drop in vacuum.
If it is EITHER and the vacuum gauge reaches the peak then why a tach too?
Also, I would prefer to use a timing light but I'm not sure if the flywheel/BB and or bell housing are correct for my engine.
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | Tom,
I have found that with different engines, vacuum and RPM don't reach their peaks with the same amount of advance. Sometimes one value will peak ahead of the other, then drop off if you continue to advance the timing as the other continues to increase. I haven't found a predictability to that occurance, but I found that advancing timing until reaching peak vacuum alone resulted in timing that predictably was well advanced from the mfr's specification, regardless of the manufacturer. I found the best compromise is to use the tach and vacuum gauge together, stopping further advance when one of the readings reached its peak, then retarding for the 1"Hg loss of vacuum. The "best compromise" setting was not necessarily right on spec, but typically it was pretty close- within a reasonable tolerance, maybe slightly toward a retarded setting toward an than an advanced setting. But with that, I would still use a timing light as the first choice, and use the tach/vacuum gauge when I couldn't use a timing light, as when the outer ring of a harmonic balancer has turned on the hub. All this was arrived at experimentally, checking quite a few engines with various methods and comparing with mfr's specs.
Hope this helps explain my method.
Harvester | | |
