4 members (baldeagle, tclederman, TexasJim50, Peggy M), 137 guests, and 4 robots.
Topics128,018
Posts1,055,341
Members48,419
6 heaven
6 heaven
I ofter find older vehicles that are setting on the ground with or without wheels that need to be loaded on a trailer. Has anyone designed some sort of platform/sled or whatever to get these "pasture relics" loaded up & unloaded on a trailer as easy as possible?
FORKLIFT!
Nah, just messin' with ya. I usually use a rollback, and the cable will yank it up on the bed, even if it doesn't have wheels.
However, I have also used wheel dollys. They're pretty cheap.
My Dad carries an extra set of tires/wheels with him when he picks up an old junker.
Hope one of these might help.
Ricky
"BlueDawg"
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
a winch on the trailer and some square pieces of plywood to rest it on if it has no wheels. then soap the trailer with dawn so it will slide.
1950 custom streetrod build
http://67-72chevytrucks.com/vboard/showthread.php?t=296770
71 corvette conv, 525 hp big block
A good, long jack-all can be indispensable in gaining a little altitude if that is the problem.
1951 3800
-hotshoe
