| | | Forums66 Topics128,089 Posts1,056,130 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | My '45 gauge lights seem to do a funny thing. They are bright when the park lights are on , but when the headlights go on, they dim noticeably. I am still on the 6 volt system. I use a headlight relay. The dimmer switch is clean, grounded and works well. The headlight switch is original. The wiring harness is a modern type. The question is, is this dimming a designed in feature, or an electrical issue? | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you don't remember the very old Disney cartoons showing old cars whose radio lamp dims when people talked same thing here
my 6v 356 does the same
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
