1 members (baldeagle), 50 guests, and 4 robots.
Topics128,014
Posts1,055,327
Members48,419
#475247 11/25/2008 3:31 PM
1 Offline
Ok, the only things i have to do is replace the quick connects on a thermostat wire which i ripped out accidentally, put the spark plugs back in, put prestone in radiator and havoline in the oil tank and im done! One wuick question, on the top of the valve cover, closer to the rear, there is a hole for a rubber hose to go in. I think the other end of that hose hooks up to the top of the intake manifold.
3 Speed Or No Speed
1965 Chevrolet C10 Stepside
That is the PCV valve.
1 Offline
What does a PCV valve do?
3 Speed Or No Speed
"Positive Crankcase Ventilation" .... puts the fumes/smoke from the engine innards back into the combustion chamber, prevents pressure build up in the crankcase from blow by
