7 members (RoadsScholar, Hanks custodian, thekid1950, Peggy M, Hotrod Lincoln, dt235sd, Thomaslb),
193
Mod | | | Forums66 Topics128,080 Posts1,056,063 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | Ok, the only things i have to do is replace the quick connects on a thermostat wire which i ripped out accidentally, put the spark plugs back in, put prestone in radiator and havoline in the oil tank and im done! One wuick question, on the top of the valve cover, closer to the rear, there is a hole for a rubber hose to go in. I think the other end of that hose hooks up to the top of the intake manifold. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | | | | | | Joined: Apr 2008 Posts: 211 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 211 | What does a PCV valve do? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "Positive Crankcase Ventilation" .... puts the fumes/smoke from the engine innards back into the combustion chamber, prevents pressure build up in the crankcase from blow by
Bill | | |
