| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Hello all, I wish to go back to the "three on the tree." I currently have the tranny on the floor. I just had my tranny rebuilt for the original transmission. I am now looking for a company that can help me with the linkage restoration and parts..Brothers? Golden State Parts? Jim Carter? Any help would be great! Thanks! | | | | | Joined: Nov 2008 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 48 | What year model / type is your truck? I am removing the 3 speed out of our 1965 C-10 and am installing a 700R4 auto. I may have some linkage parts you need if you have the same kind of truck.
tp://s367.photobucket.com/albums/oo113/RED64STEPSIDE/
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Red65, Sorry, forgot to mention that....I have a stock 1957 Chevy. I will also be listing in the for sale group the tranny I pull out of this truck. Thanks for the link Neilroy!
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | You might try looking in the Swap Meet section. Check with JIMBO59, he might have one.
Bill Burmeister | | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Does anyone have a few pictures of the linkage between the tranny and shifter box on a 55 thru 59 Chevy 3 on the tree? I am missing some parts and the assy. manual really does not show a very clear picture of what I am missing. Thank you,
Jon 1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the shop manual has a pretty detailed pic, section 7 Jon ... not many parts, just 2 rods and the arms they attach to on each end .... note 55 is different
Bill | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | go to ebay and search a 57 chevy there was a yard in your area parting several last month may be able to pull all the parts and know how they go back togather. Brad | | | | | Joined: Jul 2005 Posts: 77 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 77 | I would call Jim Carters Truck Parts. I am sure if he don't have the used parts he knows someone that does and can hook you up.
John Kinser
| | | | | Joined: Jun 2008 Posts: 714 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 714 | Just so I understand. There are 2 rods one is for 2nd and 3rd and the other is 1st and reverse. Each attach onto the tranny shifter lever (Section-7 figure 1 #29 and 28 and Fig. 3 in 1957 Chevy Shop Manual). Then the other end right onto the shifter box? Heck if that is the case,,,,I got everything! Just need to remember what box it all is in! Thanks group!
Jon
1957 Chevy 1/2-Ton TruckIn the Stovebolt GalleryMore pixThe coldest winter I ever saw was a summer I spent in San Francisco M. Twain If at first you don't succeed...skydiving is not for you! If you don't like my carbon foot print, stick it up your Prius!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you got it, Jon, 2 levers on the shift box, 2 levers on the trans, 2 rods between .... might also need some bushings at each end, especially if the rod ends or lever holes are worn at all, bronze works better than rubber
Bill | | |
