6 members (Oswald, frogfarmer, klhansen, TUTS 59, oldsteve, 1 invisible), 131 guests, and 1 robot.
Topics128,161
Posts1,056,906
Members48,458
The fly wheel ring gear on my 235 has a couple bad spots in it which are causing the starter to grind when the engine stops on those particular spots. I have a new bendix on the starter. Can the ring gear be replaced on the fly wheel or do I have to find a whole new flywheel?
Rob Mathis
48 Half Ton with 235 & SM420
Chevs of the 40s has them. I bought one for about 40 bucks I think when someone suggested turning old one around. Talk about a light bulb moment. If you heat ring gear, it expands and can be removed. New one goes on the same way.
I haven't done it but have heard how. Heat the flywheel in a BBQ grille. Then quench the flywheel with water and the ring gear should pop off. Then heat the new gear and put the flywheel in a freezer for a few hours. Then assemble new gear. Don't know if it works but sounds like it would. Hope this helps.
Ther are several threads on this and yes it can be replaced.
1951 1 Ton Completed
Thanks! I may try to flip mine around.
Rob Mathis
If you're going to all that trouble (AND you can get a new ring gear for $40) why not just replace it? It would be a REAL shame to flip it and find out that your particular situation did not work well. smile Just a thought.
Rance
66 C10 FS/LB 292/4-spd manual (I also enjoy Hang Gliding)
I'm too sexy for my hair, that's why it isn't there
The old one will just slide off with a little energetic massage with a hammer & punch. Be sure the new one is heated enough to be a free slip fit as it's installed. If there's a shoulder on the flywheel, the new gear should drop onto it easily, and align with the shoulder. If not, be sure the flywheel is on a flat surface, so the gear will shrink itself into place in proper alignment. A wobbly ring gear due to misalignment during installation is a PITA to straighten out. I use a rosebud tip on an acetyline torch to heat the gear, but it can also be heated on a barbecue grill. Just don't heat enough to turn it red hot, as this can anneal the heat-treat of the metal and make it soft enough to wear quickly.
