4 members (ShopRag, kades51, TUTS 59, dt235sd), 111 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#474837 11/24/2008 12:29 PM
my clutch has been bleeding off on my 62. I replaced the slave cylinder, which helped alot, but it still bleeds off though not near as bad. I figure I need to rebuild the clutch side of the master cylinder. Heres the big question. Can I just replace the o-ring to get me by the holidays?? Or should I replace the master cyl. If it were the brakes I would replace the master but the brakes are fine.
you can get a kit to rebuild the cyl. IF the bores in good shape! I have had some bores come back after ball honing them, but only when they had minor flaws.
Who is John Galt?
im afraid the master is gonna be toast just like the slave cylinder was. these are original parts
Well, a rebuilt unit runs around $75.00 or so, not bad if you gotta replace it anyways!
Who is John Galt?
