| | | Forums66 Topics128,030 Posts1,055,418 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 176 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 176 | I'm rebuilding a 216 with 47000 miles. I would like to how to tell if the oil pump needs replacement. The clearance between the gear teeth at the center position is .007 and the clearance between the gears and the case sides is about .003. I would like to run this engine a loooooong time before next rebuild, so it might make sense to replace the pump just in case, but I have found that slightly worn originals are often better than repros. Also wondering if anyone has a good recipe for carbon deposit removal. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | just replace it anyway when you rebuild a motor, replace the oil pump .
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
