6 members (Bill Hanlon, Gdads51, Otto Skorzeny, UtahYork, dt235sd, Ponchogl), 115 guests, and 5 robots.
Topics128,089
Posts1,056,130
Members48,435
#474496 11/23/2008 1:34 PM
what would make the right turn signal flash alot faster than the left one? All the lights are factory except the right rear which is an off the shelf replacement for trailer lights that the previous owner had put on there. I will be replacing that one. Do you think that could be the culprit? Thanks for the help.
excellant62,
This is my understanding of a flasher unit. It's a bi metal strip that acts as a switch..it is the contact that carries the current for the turn signals. When you indicate a turn, the contacts close. Because they are different materials with different rates of expansion, as they heat up from the current flow they move.
One of them actually moves away from the other and, presto, the circuit opens. It now cools off and again, presto, it closes. What this means is...blink, blink, blink!
If one side of the truck has a bulb that pulls more current than the other side, that side will cause the flasher to do it's thing...real fast. Blinkyblinkyblinky, etc.
Inversely, if a bulb is burned out, no-blinky on that side at all, or a real slow blinky.
I think that's what you have. Maybe it's the trailer light you suspect. This was the $200 version of a 50 cent problem. Good luck.
Stuart
atomarc #474616 11/23/2008 10:14 PM
2nd above. Are you sure the other side not blinking slow, because a bulb is out? Also check for resistance in the fast side as too much will speed up the blinking.
Who is John Galt?
The bulb is good. I just thought that the different tail light assembly on the right side was making that side blink faster.
