5 members (Jack Ryan, Bill Hanlon, Mike Roache, KEVINSKI, fonz8261), 127 guests, and 2 robots.
Topics128,089
Posts1,056,418
Members48,443
#474291 11/22/2008 10:30 PM
1 Offline
If anybody has a shop manual, i need the rocker arm gap specs for a 250 L6, the head is a 194, but i think the head is identical. I'm not too sure how to put on the rocker arms correctly, so any advice would be great. Thanks in advance
3 Speed Or No Speed
1965 Chevrolet C10 Stepside
Riding in the Passing Lane
I'm not shure what you mean by gap but you put the engine in a possition that the cam is not raising the lifter & tighten down the rocker nut till all the play is out of it & then tighten it 3/4 more turn.
1972 Chevy c10 Cheyenne Super
These engines use hydralic lifter so once you have zero lash, go 1/2 to 3/4 more turns down. If it has a aftermarket solid lifter cam, contact the cam maker for specs. Joe
