10 members (5 Window 9434, Hush, Southerntruck, hapydirty, klhansen, 78buckshot, Otto Skorzeny, D B Cooper, Peggy M, Hawkman),
105
Mod | | | Forums66 Topics128,049 Posts1,055,675 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 86 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 86 | Hi All,
I recently put a good used 292 out of a 66 c60 in my 66 c20. It ran great! When I changed the oil I added a half quart of Marvel Mystery Oil to help clear out the old sludge and give the lifters a good cleaning out.
On my first highway trip I was about an hour outside of town keeping a watchful eye on the oil pressure when the gauge went to zero. I shut it down and pulled over to find that the oil pan looked like it had black spaghetti coming out of it! The sludge apparently cleared itself out exposing small corrosion pits and thus relieving the motor of its oil.
I had the truck towed home ($$$) and plugged the holes and added oil to find a LOT of noise coming from the motor that only got worse. I ended up putting my spare 78 c20 292 in it (the oil pan looks great!) and it is running fine again.
Lesson learned: Inspect your oil pan very closely on used motors!!!
JC in KC "The future will be better tomorrow." Dan Quayle 1965 Chevy C10 Long Fleetside
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Wow! I guess you learned two more things- MMO is a great cleaner, and you should never clean an old engine! I would guess you also plugged up the oil pickup and some of the lifter galleries with the loose sludge.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | OMG. I thought the pan looked fine too. Never would have thought there would be rust holes in an oil pan! Sorry to hear about it! It sounded awesome when you brought it by.
I'm driving my 70 c30 w/ 292 to Des Moines and back tomorrow. Hope i don't have any problems. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | jc this isnt the 292 i sold you was it | | | | | Joined: Mar 2005 Posts: 86 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 86 | Nope Joe, it was the one from bucket. I hope to rebuild both sometime in the near future. I have an extra pan or two that will have to pass inspection!! :-)
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | i got 2 more 292s if you need something let me know | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | sounds like you may have taken out the bearings. The only way I know of to remove any appreciable amount of sludge is to physically remove it. Using MMO, seafoam, diesel fuel, etc. only loosens the large chunks and makes them plug the pickup.
I learned that lesson early and now simply buy a gasket set and physically clean any engine I use. Sometimes I get lucky and only need to lightly clean, other times I am buying a new pickup, oil pump, and spending hours cleaning.
| | | | | Joined: Mar 2005 Posts: 86 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 86 | Well, the loss of oil was the root cause of the engine failure, I know that. I was running Rotella 10w30 also which helps break up the sludge. Probably the combination successfully broke up the sludge at highway speeds, exposed the corrosion pits, causing the loss of oil. Looking back, manually cleaning out the bottom end of the engine is cheap insurance. Thanks for all the input!
