6 members (J Lucas, papas52, fonz8261, JW51, Hotrod Lincoln, 1 invisible), 132 guests, and 2 robots.
Topics128,161
Posts1,056,956
Members48,458
Junior Member
Junior Member
Is there an adapter - aftermarket - or GM that will adapt a 235 to a Turbo 350 ?
Yes, I think you'll find one at www.StoveboltEngineCo.com
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Junior Member
Junior Member
Thanks - they have one
$350.00...well, could deal with that, but what's the difference in trans length between a turbo350 and an original 4spd, and I guess I'll need a trans crossmember and shorten the drive shaft and change ujoints? Any knowledge would be appreciated..Hate to have a pretty trans adapter sitting in the dining room being all pretty..Thanks, Steve
Tab Offline
WOW! For $350 you sure don't get very much. I like the idea though.
delete my account and pictures
If you have a closed driveline truck you'll need to convert to open drive at the same time.
I have a friend using this system in a '39 panel truck who is real happy with it.
