1 members (1 invisible),
80
0
Mod | | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 11 Apprentice | | Apprentice Joined: Nov 2006 Posts: 11 | I have a 66 chevy c-10. It had the 250 3 on the tree so it has the small hump. How do i go about cutting the floor for the floor shift(hurst shifter t10 tranny)? | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 |
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | High-speed grinder and cut-off wheel. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I would use a variable speed jig saw with a fine tooth metal cutting blade. I would NOT use a recipro saw because they are too big to handle in that small area and the blades are too long.
Whatever you do use be certain first that the area below the hump cut is clear. Wear safety glasses no matter the method or tool. I know, I know...but safety pays and second chances don't come around too often. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | truckin66,
Interesting...what does the title of this thread mean, 'Richmond 4 speed'?
Stuart | | |
