1 members (2-Ton), 66 guests, and 1 robot.
Topics128,050
Posts1,055,646
#474117 11/22/2008 9:48 AM
Apprentice
Apprentice
I have a 66 chevy c-10. It had the 250 3 on the tree so it has the small hump. How do i go about cutting the floor for the floor shift(hurst shifter t10 tranny)?
truckin66 #474122 11/22/2008 12:47 PM
saw
High-speed grinder and cut-off wheel.
waldo53 #474266 11/22/2008 9:21 PM
I would use a variable speed jig saw with a fine tooth metal cutting blade. I would NOT use a recipro saw because they are too big to handle in that small area and the blades are too long.
Whatever you do use be certain first that the area below the hump cut is clear. Wear safety glasses no matter the method or tool. I know, I know...but safety pays and second chances don't come around too often.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
truckin66,
Interesting...what does the title of this thread mean, 'Richmond 4 speed'?
Stuart
