2 members (Hotrod Lincoln, Woodcmiami), 72 guests, and 3 robots.
Topics128,029
Posts1,055,417
Members48,422
#471138 11/13/2008 10:52 PM
I am putting a 350 with 350 turbo in my 62. Is the crossmember going to be in the way ? truck had a 235 with 3 speed before. Thanks TOM
Has anyone done this engine swap in a 62 ??? Tom
I haven't done it, but I believe you need to replace the bellhousing crossmember with a transmission crossmember. If you don't remove that bellhousing you'll likely find its in the way.
