0 members (),
311
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47349 07/07/2005 6:13 PM | Joined: May 2005 Posts: 19 Apprentice | | Apprentice Joined: May 2005 Posts: 19 | Is there a way to convert a 216 cid babbit-pounding engine into a fully oil-pressurized 216 cid engine?
"Nothing within the realm of the restoration process shall be alien to my experience"
#47350 07/07/2005 7:13 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I don't think so.The 216 crank is not drilled to supply oil to the bearings. A 235 crank is drilled but has a different stroke.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#47351 07/07/2005 7:49 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Yes, it can be done, but the crank has to be drilled. This was something done by the old rodders with the low-pressure 235. But even they gave it up when the "new" 235 came out in 1954.
Best thing to do is to leave it a splash oiler and have the rods machined to accept insert-style bearings. The 216 will run a long time that way.
Fred 52 3600 69 C-10
#47352 07/08/2005 8:50 AM | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | There is places that can convert it but it is pricey.I have 216 from a 39 passenger car that has been converted.
Gangster whites and straight pipes.....
#47353 07/08/2005 6:02 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Wouldn't it be easier to just get a full-pressure 235 and disgiuse it as a 216? | | |
#47354 07/08/2005 9:06 PM | Joined: Jan 2005 Posts: 279 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 279 | Originally posted by GMCpanel: Wouldn't it be easier to just get a full-pressure 235 and disgiuse it as a 216? If you are talking to me,yes it would,I have done that in the past.I have 3 nos 54' 235 short blocks that I could dress up as a 216 but not for the car I putting this in,it is pretty rare and I dont want to get the purist mad :p (namely me).Now to actually buy that darn car.
#47355 10/03/2005 4:25 PM | Joined: Sep 2005 Posts: 15 Junior Member | | Junior Member Joined: Sep 2005 Posts: 15 | What's involved in making the 235 look like a 216? Valve cover? How hard is that to do? Do you recommend adding a oil filter? Most bolt on fliters I've seen are pretty pricey.
Cbaymac
#47356 10/03/2005 8:56 PM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | There is also a mod to move the position of the water pump up to where it was on the 216, using the 216 waterpump. There is a thread on this.
The oil filter assemblies appear quite frequently on Ebay . That is where I bought mine. | | |
#47357 10/03/2005 10:08 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Originally posted by Cbaymac: What's involved in making the 235 look like a 216? Valve cover? How hard is that to do? Do you recommend adding a oil filter? Most bolt on fliters I've seen are pretty pricey. Here are shots of my '54 235. http://www.thriftauto.com/fredsengine.jpg http://www.thriftauto.com/fredsengine2.jpg The early 235 had the high water pump, same as the 216. I used the 216 valve cover, with mounting stud kit from one of the vendors. I also used the original oil filter.
#47358 10/04/2005 1:22 AM | Joined: Sep 2005 Posts: 15 Junior Member | | Junior Member Joined: Sep 2005 Posts: 15 | Fred, great looking engine. Thanks for the info on the oil filter. What did you pay if I may ask? Did you have to dill the block for the oil fittings? http://mcpheter.com/51PU.jpg
Cbaymac
#47359 10/04/2005 10:12 PM | Joined: Jan 2005 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 63 | Look at this link for Becks, http://www.inliners.org/becks/ it's what they call a "full flow 216". Don't know about cost effective, but they do it. I've heard you can make a 235 look just like a 216, except maybe the side cover.
1941 AK named "PETEY" my buddy.
#47360 10/05/2005 8:35 PM | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | I had a '39 Chev. 216 pressure drilled and macined for insert rods. Ran great and I turned it over 5000 RPM often, it never had lower end problems. The early 235's up to '53 look just like 216's, tall side cover and all, so that should be no problem, just put a later oil pump and drilled crank and it works fine and nobody will know except for the numbers on the block. | | |
