1 members (2-Ton), 68 guests, and 2 robots.
Topics128,214
Posts1,057,488
Members48,473
59 235 with a nice clean rebuild. Got it running and driving it a few miles after breaking it in. The machine shop set the valves cold good enough to go. Told me to make sure I adjusted them hot. When would you adjust them, asap or after a couple of hours of run time or even longer. Ralph
~ Rasman
1971 Chevy C10
"Old Yeller"
Saga: "'Old Yeller' ... More than a Pristine 1971 Chevy"
1959 Chevy 1/2-Ton
In the Legacy Gallery
Bring it up to operating temp and adjust now. After a couple hundred miles re-torque the head and check the valves again.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
The step I missed was not re-torquing the head before adjusting the valves, after the first run. I found the torque values on the head bolts were way down from when I did the build. The manual advises to re-torque the head.
1951 1 Ton Completed
All head gaskets take a little "set" when they warm up, even the supposed "no-retorque" types. On something as easy to reach as a stovebolt engine, I choose to re-check the head bolt torque after the first warm-up, then tweak the valve adjustments if necessary. The valve cover has to come off anyway.
Isn't there one headbolt on these engines the requires you to remove the rocker assembly? It's the #1 headbolt, the first bolt in the torque sequence, and it's located right under the center oiler.
I thought I remembered this as the stumbling point in the 'easy to reach' scenario. Maybe a crows foot wrench would do it, but I don't think that will work either.
So a head retorque requires you to remove the rocker assembly, yes or no?
Stuart
I've used an oddball offset wrench for that one, a tool I inherited from my father. It's not all that difficult to make one out of scrap metal with a little creative welding, though. Otherwise, I guess pulling the rockershaft is the only other option.
My head is sort of halfway between the 216 and the newer 235. There are two inner bolts on mine that I use a socket with a universal on it. These are as you say near the center of the head. For the front most one, I remove the next rocker shaft bolt, undue the valve adjuster, slide the rocker forward out of the way and then torque the head.
Don't forget to check the torque on the rocker shaft assembly mounting bolts before you adjust as well. It will make a difference.
I don't recall having to take the rocker assembly off to torque my head bolts either. IIRC, my socket was just the right hight to clear it, it's a Mac 3/4 thinwall semi-deep impact socket, and I was using a Snap-On torque wrench.
Bill Burmeister
The head bolt pattern changed in 1953. My head is a 1951 and that probably makes a difference.
That's probably it. Been a while since I've messed with a 216 or early 235.
Bill Burmeister
