| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 199 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 199 | 59 235 with a nice clean rebuild. Got it running and driving it a few miles after breaking it in. The machine shop set the valves cold good enough to go. Told me to make sure I adjusted them hot. When would you adjust them, asap or after a couple of hours of run time or even longer. Ralph | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Bring it up to operating temp and adjust now. After a couple hundred miles re-torque the head and check the valves again. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The step I missed was not re-torquing the head before adjusting the valves, after the first run. I found the torque values on the head bolts were way down from when I did the build. The manual advises to re-torque the head. | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | All head gaskets take a little "set" when they warm up, even the supposed "no-retorque" types. On something as easy to reach as a stovebolt engine, I choose to re-check the head bolt torque after the first warm-up, then tweak the valve adjustments if necessary. The valve cover has to come off anyway. Jerry
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Isn't there one headbolt on these engines the requires you to remove the rocker assembly? It's the #1 headbolt, the first bolt in the torque sequence, and it's located right under the center oiler.
I thought I remembered this as the stumbling point in the 'easy to reach' scenario. Maybe a crows foot wrench would do it, but I don't think that will work either.
So a head retorque requires you to remove the rocker assembly, yes or no?
Stuart | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | I've used an oddball offset wrench for that one, a tool I inherited from my father. It's not all that difficult to make one out of scrap metal with a little creative welding, though. Otherwise, I guess pulling the rockershaft is the only other option. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My head is sort of halfway between the 216 and the newer 235. There are two inner bolts on mine that I use a socket with a universal on it. These are as you say near the center of the head. For the front most one, I remove the next rocker shaft bolt, undue the valve adjuster, slide the rocker forward out of the way and then torque the head. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Don't forget to check the torque on the rocker shaft assembly mounting bolts before you adjust as well. It will make a difference. I don't recall having to take the rocker assembly off to torque my head bolts either. IIRC, my socket was just the right hight to clear it, it's a Mac 3/4 thinwall semi-deep impact socket, and I was using a Snap-On torque wrench.
Bill Burmeister | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The head bolt pattern changed in 1953. My head is a 1951 and that probably makes a difference. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | That's probably it. Been a while since I've messed with a 216 or early 235.
