1 members (78buckshot),
64
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47294 07/06/2005 2:25 AM | Joined: Jul 2005 Posts: 52 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 52 | My 235 was running really ruff. After points & plugs & other checks I found the valve closest to the firewall to be stuck open.
I backed out the adjusting screw & put the pushrod into proper position. I retightened the adjusting screw & found it to be a 1/4 inch more of tightening to touch the pushrod properly. This tells me that the valve is over extended. The valve spring looks to be more compressed than the other valve springs. Where do I go from here?
By the way...here's the really bad news...This condition happened sometime last year. I've been running the motor...trying to find my problem. Last fall I ran the motor for at least 3/4 of an hour to get it warm before putting it into storage...all the time I've been pounding this pushrod & rocker...I'm a bonafided idiot!
How do I go about fixing this? Can I free up that valve somehow & go about my way? Do I need to remove the pushrod to look for damage? Do you think my cam is damaged? Help!!! | | |
#47295 07/06/2005 2:48 AM | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | sound like your gonna hafta pull the head and replace the valve.you might try removing the rocker and give the top of the valve stem a good smack with a hammer it might unstick if its not bent.if it does add some marvel mystery oil to your engine oil should keep it from sticking again.also check the spring to make sure it isnt broken. | | |
