7 members (mick53, Tiny, Southerntruck, HandyAndy, TUTS 59, 2 invisible), 82 guests, and 2 robots.
Topics128,093
Posts1,056,046
Members48,433
#472719 11/18/2008 11:50 PM
I am getting ready to pull out my 216 to reseal it. It leaks very bad. The fellow that did the overhaul job on it a few years ago didn't know what a gasket was I guess. But hear is my main concern.
1.) What is the best procedure in removing and installing a new rear main seal?
2.) Which seal is the best to use: Rubber or the old rope type?
Kinser1970 #472731 11/19/2008 12:04 AM
Maybe somebody can correct me if I'm wrong, but I don't think the rubber seal will interchange with a rope seal on a 216, will it? On the later-model engines, there's s very different machined surface where the seal goes when it's equipped with the rubber lip seal.
If you'll use the search function, you will find page after page of methods, suggestions, and sneaky tricks on changing rear main bearing oil seals, including a couple I've written. I think there's at least one tech tip entry on rope seal replacement, too.
Riding in the Passing Lane
There is a changeover rubber seal for 235 engines but I don,t know about the 216.
1972 Chevy c10 Cheyenne Super
Best Gasket makes rope seals from teflon impregnated kevlar fiber. ( Knock it off Lovett! ) nono When the feds made the gasket companies take asbestos out of the rope it made them hard to seal. Patrick's sells Best, So does Kanter and Eggie, I think. The ropes come with a spacer to leave the right amount of fiber past the bearing, a razor blade, and a stick to protect your thumb. I replaced a leaker on my 270 and it doesn't leak a drop!
"I wonder if God created man because he was disappointed in the monkey?" Mark Twain
