1 members (SlimSix), 129 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#4727 10/14/2002 1:20 AM
has anyone replaced the original rocker arm oil line that come out of block through the water jacket and on up behind the pushrod pan to rocker arms? the line on my 1951 chev. 216 is broke off just at the block, and I don't see the other end of it even with oil pan removed. thanks Bill poper@adelphia.net
Bill 1951 3/4 ton 5 window pick up
1955 GMC 1/2 ton longbed automatic
#4728 10/14/2002 8:30 PM
One end enters the block under the manifolds. The other end comes out under the pushrod cover.
Jim
Jim
