A friend asked me to check his Stromberg 97 setup. He has a problem with spark plug fouling and oil dilution. I have foumd that the lh main jet is driping gas at idle and the rh is not!
I have changed the float level and even swaped the jets left/right. Still leaks on the lh side. Can you give me any guidence on what to check?
if it dosen't need fixed, break it
