2 members (J Lucas, Erniegp), 78 guests, and 2 robots.
Topics128,054
Posts1,055,780
Adding powerbrakes to a 70 gmc with inline 250. I am noticing that once booster is installed on the firewall I wont be able to fit the stock are cleaner. How was the factory setup? I can always put on a small cleaner but figured there must be a stock set up that works.
Mac
I just came upon the same problem yesterday while fitting my booster on my 66 one ton. I actually went to the local u-pull-it to see if I could find a smaller unit off of an import or something. I don't care for those small chrome ones you so often see. I saw some fuel injection type set-ups on some of the cars that I thought might work......you know, the kind that have a formed hose that goes from the top of the throttle body, to a remote air-box. I haven't decided what I'm going to do yet.
Also did you find that when you mounted the booster, the rubber boot on the backside didn't protrude through the firewall enough to seal the opening that the pedal travels through? I need to figure out a way to seal that with a universal rubber boot of some sort, or the cold air is going to blow right on the family jewels........
The factory installation has a bracket that angles the booster towards the fender. I've heard of an air cleaner used on vans with a six that puts the air cleaner on the other side of the engine. Can't help with the rubber boot.
Larry
I don't own a vehicle that isn't old enough to drink.
