4 members (greenie-reddy, Jon G, cmayna, dt235sd), 26 guests, and 4 robots.
Topics128,021
Posts1,055,372
Members48,420
#471951 11/16/2008 4:44 AM
Hello, I just bought a 63 C-10 with 3 speed trans w/column shifter. I am having an intermitent problem shifting. It shifts fine sometimes, then sometimes does not want to go into gear, like I have no clutch. Tonight was the worst it has been, seemed to stay in gear with the clutch depressed. Then all of a sudden it was fine again. Is this a linkage problem or a clutch problem? Any help would be appreciated as I don't know alot yet about these manual transmissions.
Jay McIlwaine
sounds more like a hydraulic clutch. are you sure the truck is a 63?
Jay, Pull the inspection cover off the bottom of the bellhousing and have a friend operate the clutch to see if it's working. If so, the problem is most likely in the transmission... or at least that's my best guess.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Riding in the Passing Lane
It sounds like the clutch disc is sticking to the flywheel or pressure plate. It could have oil on the facings or is hanging up on the trans shaft. Like Woody says pull the lower cover & see if you can tell whats going on. Thats about the simplest model to put a clutch in as they come.
1972 Chevy c10 Cheyenne Super
Thanks for your input guys, I will check it further. I also noticed the clutch doesn't really engage till the pedal is very close to the top. Do you think tightening the nut on the adjustment rod would help? Thanks.
Jay McIlwaine
The linkage should be adjusted so you have about 1 in. freeplay in the pedal.
You won't believe this: I checked the manual trans fluid and noticed it was very low. Filled it up and haven't had a problem since! Can't get a cheaper fix than that.
Jay McIlwaine
