5 members (ShopRag, Phak1, Bill Hanlon, Otto Skorzeny, 3B), 116 guests, and 4 robots.
Topics128,034
Posts1,055,547
Members48,425
#47193 07/03/2005 11:39 PM
Junior Member
Junior Member
Hey guys, I need help i.d.ing my engine . It is in my 50 1/2 ton pickup.The block numbers behind the starter are CON3 E194 any help would be great. Thanks Bud
#47194 07/04/2005 4:27 AM
Sounds like numbers from the 230/250/292 series. The CON3 means casting conveyer #3, the next series is the date. E=May, 19=date, 4=last digit of year, could be 64, 74, 84. There should be a 6 or 7 digit number just forward of the date, larger numbers, might be lower on the block. This is the casting number, which can be looked up at www.inliners.org
For a quick verification of this series, engine has side mounts with a spin-on oil filter at the front, right side. The 230/250 has the side mounts opposite each other, the 292 has the right mount forward of the distributor.
Fred
52 3600
69 C-10
#47195 07/04/2005 7:17 PM
Junior Member
Junior Member
Thanks Fred T. The 7 digit number 3835911 and your help tells me its a (53-55) 235. Stovebolters com thru again
