0 members (), 51 guests, and 7 robots.
Topics128,021
Posts1,055,355
Members48,420
#471825 11/15/2008 10:33 PM
On a 49 chevy truck 3600, was there only 1 tail light, or two? (Original from the factory) Thanks
One, second one was offered as an accessory.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Denny, thanks again. So in your opinion, having 2 would be considered original, right? I'm building this truck mostly for shows, it won't be driven much, so I could get by with one if that would make it more original.
Ex Hall Monitor
Ex Hall Monitor
It would be considered period correct. Most folks wouldn't know the difference.
Tiny #471858 11/16/2008 12:40 AM
I know they were offered as an accessory, but I can't ever recall seeing a new pickup from the Korean War era or earlier with 2 tail lights. People in this area just didn't spend money on accessories.
Yes as tiny pointed out, as a period correct accessory it would be acceptable by the judging bodies, just as a RH sun visor, mirror, fender mounted turn signals, bumper guards, radio, spotlight, cigar lighter, glove box light, under hood light, inside RV mirror, deluxe trim are all period correct accessories or production options.
Accessories and Options were to numerous to mention here, but click this link to TOCMP and take a look at a typical list of that period. http://chevy.oldcarmanualproject.com/accessories/1951am/index.htm
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Since there is noway to look and the vin. and verify if the origional owner install a rt. tail lamp, go ahead and put one on. Who's to say it didn't have one installed at the dealer. Just make sure the mounting bracket is correct or you are BUSTED!
For me just use one-- we know for sure it had at least one.
But then again I am going to put 2 on a 41 and change the wiring to make the tail stop and turn lamps work with the 2 lamps only.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
