0 members (),
191
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Anybody mind measuring their 261 or 235 (later series) dipstick tube length. I need to make one for my engine.
Much appreciated.
Dave
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I was taught to change the oil, add the 5 quarts or whatever the capacity is and then cut the tube to the length that it measures full. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | That's exactly the way I did it. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | Just so happens I'm doing that this weekend. My 261 tube length is about 8 and 1/4 inches. I say about because mine had a 10 degree bend at the middle away from the block and I straightened it to measure for a new one. There is also a slight flare on the end wwhere the dipstick seal seats. My dipstick is 15 and 1/2 inches from the seal to its tip. The full mark is 1 and 11/16 inches from the bottom tip. The overall length of the dipstick from pull handle to tip is 18 and 1/4 inches, but I think that is not important as different handle designs were used over the years.
Drew
| | | | | Joined: Apr 2008 Posts: 203 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 203 | Thanks a lot Drew. I can finally get this one done and move on.
Dave
