5 members (Brian Moore, texas46, dt235sd, TexasA&M48Truck, Steelonsteel), 59 guests, and 1 robot.
Topics128,022
Posts1,055,381
Members48,422
#471460 11/14/2008 8:39 PM
I recently got new oil filter lines for a add on oil filter on a 1951 216 engine.
The fittings on the filter housing end were a reular flare fitting,and I need inverted flare fittings.
I called the vendor, and they informed me that this is the only one they make,
Does anyone know where I can get oil lines with a 1/4 pipe thread on one end and a 1/4 inverted flare on the other??
The filter is an AC.
I have a FRAM (but AC uses the same fittings) in my 1951 3604 and I got new replacement lines from Jim Carter and had no problems. I'm curious as to where you got your lines. I assumed all of the vendors used the same manufacturer. I'm pretty sure you have the incorrect brass fittings on the canister itself. I restore these old canisters and get new inverted flare fittings at my local Ace Hardware. I cannot get them at any of my FLAPS. If you can't find them locally, send me a private message and I will hook you up. Good luck, Jeff.
