7 members (Peggy M, mick53, cmayna, Lostbuthaulinass, RaNfLaS, Southerntruck, JW51),
181
0
Mod | | | Forums66 Topics128,114 Posts1,056,285 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#47064 07/01/2005 12:00 AM | Joined: Jun 2000 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2000 Posts: 50 | I am rebuiding my Rochester BC 1 barrel on my 235, the bottom flange of the carb that sits on the intake manifold has a small hole that is open to the interior of the carb, hoever, when the carb is bolted down on the manifold this small hole is covered and closed by the manifold gasket .. I seem to recall a post that said this hole was supposed to be open to the manifold ... anyone know anything about this? Thanks
1951 Chevrolet 3100 AD Pickup
#47065 07/01/2005 3:24 AM | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | JNash,
Yes, there is a hole (for vacuum?) in the base of the carb that hole should match up with a hole/notch in the carburetor gasket that also lines up with a notch in the carburetor-to-intake spacer/insulator.
Tim | | |
#47066 07/01/2005 3:58 PM | Joined: Jun 2000 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2000 Posts: 50 | Tim - Thanks for the response, I'll try opening it up and see what happens!
